Tres Martin’s Safety Corner: Inspect Religiously >
Tres Martin?s Safety Corner: Inspect Religiously
Old 10-10-2013 | 08:34 AM
Correspondent
Correspondent
Default Tres Martin’s Safety Corner: Inspect Religiously
The latest installment, http://speedonthewater.com/in-the-ne...ct-religiously.
When it comes to safety, attention to small detail is crucial.
Matt Trulio is offline
Old 10-10-2013 | 09:27 AM
So true...
Lost a tie bar once coming on plane, not pretty.(the nut fell off the bolt) Thank got I wasnt up on plane at speed - i'd be dead.
Keith Atlanta is offline
Old 10-10-2013 | 11:59 AM
Correspondent
Correspondent
Originally Posted by Keith Atlanta
So true...
Thanks for chiming in, Keith. Additional real-world stories likes yours do so much to bring home the points that Tres Martin makes.
Old 10-10-2013 | 01:19 PM
C_Spray's Avatar
Diamond Member #001
I found a split high-pressure fuel line while performing the sniff test after refueling. "Sammy Safety"...
Also once found the cap off of the water flush fitting, and the engine seacock shut. Not necessarily a safety concern, but replacing impellers is a pain in the ass.
C_Spray is offline
Old 10-10-2013 | 01:38 PM
^^^As did I...
nothing screams danger like high pressure gasoline mist in a bilge!
nukemnet77 is offline
Old 10-10-2013 | 02:54 PM
Correspondent
Correspondent
Thanks Chuck and Nuke. You know, this could become a pretty interesting—and useful—thread if people keep posting some of the not-so-good things they've discovered in "pre-flight" inspections.
Old 10-10-2013 | 04:31 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I give the cat a pre-flight religiously . A walk-around while still on the trailer to inspect the hull and drive assembly . I open the engine hatch before firing and do a sniff test then check for any fluid leaks . Upon firing up the engine I run my fingers around every fuel line connection , check fuel pressure then check again for any leaking fluids . Over the years this routine has saved many boating days from turning to chit . Just treat your equipment as if it were an airplane because we all know what happens if something turns to chit up there .
the deep is offline
Old 10-10-2013 | 04:42 PM
I kind of half-assed my inspections before...I think I'm going to get quite a bit more serious after these stories!
Captain YARRR is offline
Old 10-10-2013 | 04:52 PM
One time during Pre flight inspection I noticed my skank forgot my Crown Royal Black!!
Unbelievable!
ICDEDPPL is offline
Old 10-10-2013 | 08:01 PM
C_Spray's Avatar
Diamond Member #001
Also, I once climbed into my boat to find Matt Trulio sitting there. A life-changing experience, for sure....
C_Spray is offline
