Sierra 25w40
Old 10-10-2013 | 12:27 PM
Blue Oval
Default Sierra 25w40
Anyone use Sierra oil? My local pats store stopped handling Merc oil.
mainstreet is offline
Old 10-10-2013 | 01:01 PM
There are a lot of suitable oils. I would think a lot of those are better that Sierra.
JRider is offline
Old 10-10-2013 | 05:00 PM
Blue Oval
I had to make a run to Petoskey, I picked up some merc oil, problem solved.
Old 10-11-2013 | 07:23 AM
TUFFboat's Avatar
Its all made in the same place, branded different. base stock is the same, sometimes they may alter the ratios of the additive package. If it has the right stamp recommended 'BIA' TCW3 NMMA etc it must be good.
Mercury, walmart, Sierra, BRP don't have there own refinery. There are only 3 refinery companies in north America. Everyone else orders what they want and uses there own marketing machine of BS to sell it.
If it is labeled with the ratings and certifications you need, its fine.
TUFFboat is offline
Old 10-11-2013 | 09:49 AM
BUP
Citgo makes / blends a lot of oil for the marine OEM's. 2 stroke and 4 cycle oils.
Citgo also makes gear oils for some of the marine OEM's. Mercruiser gear oil is made by Citgo but Mercruiser high performance gear oil (green color) is made by Bel Ray.
Also I think there is only 6 or 7 additive companies left that the oil blenders can buy from. Shell, Mobil & Lubrizol are 3 of them.
I think the Sierra motor oil falls under a group II for their base stock. There is a difference in oil brands especially on the base stocks side of things plus the additive packages being blended into the base stocks. Group I thru III and Group IV & V in which are your true synthetic oils for base stocks.
BUP is offline
Old 10-11-2013 | 09:55 AM
While this is true as far as refineries go, there are hundreds of "blending" plants that mix in the propriety additive packages to meet specifications. Personally I would stick to an off road oil of some kind. EPA regulations and new car technology is forcing oil manufactures to remove some of the additives that are beneficial to our older technology and high strain environment.
That being said....when is the last time you heard a machinist say "Yup, she blew up because you brand x oil, if you used brand y this would not have happened" ? Personally for me....never
4bus is offline
Old 10-11-2013 | 03:46 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Mercury/Sierra 25W - 40 oil is a 25 straight weight and a 40 straight weight oils combined together. Same oil. Same drive oil also.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 10-11-2013 | 09:01 PM
Wobble's Avatar
SORE MEMBER
I have no idea where you came up with only 3 refining companies. I can assure you that I work for many more than that.
In no particular order.
Exxonmobil
Shell Motiva
Total
BP
Phillips
Citgo
Koch
Chevron
Houston Refining
Valero
Sunoco
Marathon
Hovensa
Lubrizol is behind many of the after marker oils
Wobble is offline
