Cams Etc....
Old 10-15-2013 | 08:34 PM
Default Cams Etc....
Gen 6 step nose cams. All hydraulic roller:
1) Crane 226/232 .587/.598 114 LSA (exhaust lobe cut on small block master for a little less lift and 2 degrees less duration) Designed for a nice idling EFI. Installed, but never ran. $150.00
2) Arizona Speed and Marine 224/230 .540/.540 114 LSA I believe this cam was ground by Schneider. This cam would be a good cam for an easy 454/502 mag mpi upgrade, with minimal headaches...had a nice, smooth idle and definitley more on top.Only needs moderate valve springs and stock roller lifters. I ran this cam for awhile and changed to an Ultradyne which didn't have a nice idle, Not even a season on this ASM cam. $100.00
3) Ultradyne (now Bullet) 226/234 .601/.601 114 LSA. I found out after I removed this cam, that it needs to be installed at 5 or 6 degrees advanced for a nice idle because of the assymetrical lobes. This cam had tons of power. It has a surface rust spot on the step nose journal appx. 1/8" in diameter and smaller spot on the flank of one of the lobes...I believe these will polish out.Because of this, I will sell for just
$25.00....if you cant use it, I'll give your money back.
Comp 929-16 valve springs; new but installed on cam #1 $75.00
Titanium Retainers; new but were installed on cam #1 $75.00
Items located in Kansas City. If you are a familiar name in good standing on this forum, I'll send you the items to inspect first. Figure $12.00 shipping on cams. Thanks, Dave
liquidlounge is offline
Old 10-15-2013 | 09:07 PM
your pm is full, I;ll take the Ultradyne cam and valve springs. Paypal work for payment?? Thanks, Anthony
METALMUNCHER72 is offline
Old 10-16-2013 | 08:42 AM
Metal- I will save them for you...I have the cam, but the springs went w/ the heads to be fitted for T&D rockers. I will have back in about 1 week. I'll contact you then. Thanks- Dave
Old 10-16-2013 | 08:31 PM
thanks!
