Mercury number 6 drive oil? >
Old 10-17-2013 | 06:58 AM
LV's Avatar
LV
Default Mercury number 6 drive oil?
What are people using?
LV is offline
Old 10-17-2013 | 07:06 AM
Torco was the recommended oil, but merc recently came out with a new hi perf oil
Unlimited jd is offline
Old 10-17-2013 | 07:08 AM
LV's Avatar
LV
What torco is it?
LV is offline
Run the heavy blue/green old merc hi-perf stuff, maybe 1mph slower but much safer for the drives
302Sport is offline
Old 10-17-2013 | 07:28 AM
colabella rebuilt mine and he told me to use torco MTF.that,s what he put in them.
mike tkach is offline
Old 10-17-2013 | 10:36 AM
LV's Avatar
LV
Thanks guys!
LV is offline
Old 10-17-2013 | 11:44 AM
Coolerman's Avatar
PF Marine
A Torco rep told me a few years back that the RTF is a superior oil than the MTF. The only difference is that the MTF will absorb water if you have a propshaft seal go bad (you're screwed anyways).
Some lab tests showed that the merc gear oil is about as good as the torco RTF, but the merc gear lube will absorb water better. I know TNT puts the merc gear lube in drives that have pre-loads setup for turbine applications or large piston powerplants.
That being said, we run the NEO oil from the bravo shop. You can feel that the stuff is stickier than anything else, and our oil has been less discolored when changing it than any other oil. And we run some pretty big power through it on a heavy boat with a 1.5 gear set. We don't baby it either. Also, there are no issues with the NEO oil going through the #6 filter.
Lab tests have also shown that the Amsoil gear lube is good stuff. Don't run the engine oil though in your drives like some people say as it is completely the wrong additive package. Also, Red Line oil is big no-no in drives.
Coolerman is offline
Old 10-17-2013 | 12:27 PM
Knot 4 Me's Avatar
I've read where some people are running Amsoil 10W40 in their drives because Teague said he runs it in his #6's. NFW I'd do that.
Knot 4 Me is offline
Old 10-20-2013 | 12:16 PM
Coolerman's Avatar
PF Marine
Yep, it is the completely wrong additive package. It might work in some cases, but for pushing the limits it is a bad idea.
Old 11-12-2013 | 07:08 AM
SS930's Avatar
I've run Torco RTF, MTF, and even a 50:50 mix of both types in mine with excellent results (no shavings or issues).
I've heard several shops say they recently switched over to the newer Merc oil, although I have no experience with it and have also not seen the pricing. If it's priced reasonably, I will give it a try next season.
SS930 is offline
