Imco Super Fuel Valve 6 Port >
Old 10-19-2013 | 01:14 PM
INDY27's Avatar
Default Imco Super Fuel Valve 6 Port
Perfect condition, removed from Eliminator Daytona, comes with Aeroquip fittings as pictured. $300
IMCO 6 Port SuperFuel Valve
PN: 06-2095
SuperFuel electric fuel selector valves are designed for high capacity flow. SuperFuel valves flow 250 gallons per hour at a 400-pound maximum operating pressure. Designed with a brass ball valve and 1/2" thru-hole for a non-restrictive flow. An internal micro switch allows you to read each fuel tank sender as you switch from one tank to the other. IMCO's unique mechanical override allows you to switch over in case of electrical failure. SuperFuel valves measure 4" Wide x 1/4" Long x 2" Deep, and 1/2" NPT Ports.
Model 06-2095
Manufacturer IMCO MARINE
MSRP NEW:
Price $595.00
Attached Thumbnails Imco Super Fuel Valve 6 Port-imco-super-flow-001.jpg   Imco Super Fuel Valve 6 Port-imco-super-flow-002.jpg
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 10-19-2013 | 02:18 PM
I want it. PS your pm box is full. thanks ,Chris hf...478 451 9186
halffast is offline
Old 10-19-2013 | 03:29 PM
INDY27's Avatar
Chris, just cleared my pm's. Will call you in a few.
INDY27 is offline
Old 10-20-2013 | 09:59 AM
INDY27's Avatar
Sold
INDY27 is offline
