Livorsi GPS antenna >
Livorsi GPS antenna
Livorsi GPS antenna
Old 10-20-2013 | 07:59 AM
Default Livorsi GPS antenna
Bought a livorsi gps speedometer off ebay. Came with the tattle tale switch is all. Need an antenna. Thanks for the help
jtbooten is offline
Old 10-20-2013 | 08:06 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Beware, some have batteries in them, and some do not. The batteries go dead, and they have to be replaced by Livorsi or resoldered in by someone who knows what they are doing... or update gauge to be compatible with new antennae that does not have a battery. It's probably best to check with Livorsi directly.
Sydwayz is offline
Old 10-20-2013 | 09:42 AM
If you have a chart plotter with a built in antenna, can it be plugged into that??
phragle is offline
Old 10-20-2013 | 12:34 PM
If I had a chart plotter it could but I boat on small lakes and don't have one.
Thanks for the advice on the antenna. I didn't think about the battery.
jtbooten is offline
Old 10-20-2013 | 03:59 PM
Hopefully you bought a recent model speedo. The new antennas are not compatible with the older gauges.
HyFive578 is offline
Old 10-20-2013 | 04:49 PM
I did. I made sure of that.
jtbooten is offline
