Holley 4150 bent throttle linkage thx USPS >
Old 10-21-2013 | 05:02 PM
Default Holley 4150 bent throttle linkage thx USPS
Bought a barely used Holley 4150 HP 850 marine carb with titanium jets and the goods from a friend. The post office dropped it and bent the heck out of the throttle linkage. All of the through shafts appear to be straight and there is no other damage, but the throttle linkage looks hammered. Should I bent it back using the two pliers method or Oder an entire baseplate from proform or holley? Here's a picture. Did I mention I despise USPS?! Top part of linkage is fairly bent as well.
Borgie is offline
Old 10-21-2013 | 05:25 PM
I had to bend my buddies throttle linkage on a carb he bought. Looked like someone whacked it with a 3lb sledge. Aholes. But it works fine now.
MILD THUNDER is offline
Old 10-21-2013 | 05:34 PM
This one appears to be bent at like 3 different angles! I'm a perfectionist so if I can't get it damn close I'm just going to buy a new base plate for it. If so would you go Proform, quickfuel...? Figure they are all the same regardless of marine vs street regarding throttle plates for mech secondaries.
Borgie is offline
Old 10-21-2013 | 05:51 PM
http://allcarbs.com/detail.php?pid=4...1&ctgn=4&stt=0
Old 10-21-2013 | 05:55 PM
I knew you would come through! There goes another $100 lol. My carb is black with ARP stainless bolts so I think the red will look BA.
Borgie is offline
Old 10-22-2013 | 02:08 PM
bcfountain's Avatar
Registered User
service like that is why the post office is in the shape there in now........and other issues.
bcfountain is offline
Old 10-22-2013 | 05:42 PM
Registered User
Are you talking about the link bar between the primary and secondary's? If so they come bent like that from holly it's a progressive linkage. They sell a adjustable one if you want to change the rate that the secondary's open. They also sell strait ones and ones that open at 40% and 60%.
IRWIN is offline
Old 10-22-2013 | 06:12 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I'm having trouble seeing anything bent there that shouldn't be . That bent link is an adjustment as to when the secondaries come on .
the deep is offline
Old 10-22-2013 | 06:34 PM
Sounds like a packaging error
ICDEDPPL is offline
Old 10-22-2013 | 07:18 PM
Looks to me like the bottom of the throttle lever might be bent in slightly.It looks like it would straighten easily if it's even necessary.
motor is offline
