Prop and prop shaft height.
I bought a 2001 - 26 Daytona. I put one of my 650 HP engines and -2 shorty from the SCARAB in it. I have been told that the prop shaft should be 1 inch higher than the lowest point of the rear step just forward of the transom. I am building a -3 inch shorty that will put the shaft at 1/2 inch above.
Where are You guys running yours and what prop are You running?
Will I need to run a 5 blade with the higher X.
What diameter prop?
Steve
What diameter prop?
Steve
