What hp do you think
Old 10-22-2013 | 07:37 PM
JDB1981's Avatar
Default What hp do you think
I am building two motors they are 468 cu in they are 8:1 compression dart pro one aluminum head 310 cc Coustom c to match b&m 250 blower with 6# of booste how much horse power do yor think it will make
JDB1981 is offline
Old 10-22-2013 | 07:51 PM
550-570 hp depends on cam profile
MDGperformance is offline
Old 10-22-2013 | 08:01 PM
JDB1981's Avatar
Thinks I am getting with a camotion on cutting a cam
JDB1981 is offline
Old 10-22-2013 | 08:36 PM
Exhaust, and cam specs?
hogie roll is offline
Old 10-22-2013 | 08:47 PM
I'll say 600-650 with a good cam. Considering, a 525sc plus better heads, bigger blower, more compression, and assuming you use a better cam.
Old 10-22-2013 | 09:32 PM
johnnyboatman's Avatar
hard to say , 675ish with those heads, and a good cam, single or dual carbs?
johnnyboatman is offline
Old 10-23-2013 | 12:54 AM
600-625 hp would be my guestimate
Griff is offline
Old 10-23-2013 | 05:26 AM
JDB1981's Avatar
Dual carbs header
JDB1981 is offline
Old 10-23-2013 | 06:04 AM
kreed is offline
Old 10-23-2013 | 06:31 AM
Smitty's Avatar
My guess is 600HP. I would caution about going any higher than 6 lbs with that 250 blower. It will heat up the intake air temp and cause detonation which will kill a boat motor quickly.
Smitty is offline
