Engine keeps on runing >
Old 10-22-2013 | 08:25 PM
Default Engine keeps on runing
1983 cig with carb 420
Engine starts ans runs (was just put in after rebuild)
engine wont shut off unless you pull the connector out of the thunderbolt 4 module
plug the module back in hit start and it runs
any idea what could be wrong here?
also 1 bank (side) of gages dont operate now...as if there is no power there to energise
Any ideas on that one?
welfare racing is offline
Old 10-22-2013 | 09:06 PM
use your trusty test light on the gauges, If they have power its a ground issue. take same test light to the motor, the ignition has power when it shouldn't..work your way backwards..... if you haven't found the problem by the time you get to the plug the problem is under the dash. start with the ignition switch. Does the lanyard kill it?? What did you change?
phragle is offline
Old 10-22-2013 | 09:50 PM
Sounds like you have something back-feeding 12v to the ignition circuit. I'd look at wherever the gauges that aren't working get their power. I'd suspect it's the same issue causing both problems. I once had a gauge light miswired to a hot-terminal on one of my tachs, and if the dash lights were on, the engine would continue to run.
RT930turbo is offline
Old 10-23-2013 | 12:38 PM
Steve H's Avatar
artselectricinc.com
Check the wiring on your alternator. Make sure it matches the other engine.
Steve H is offline
Old 10-23-2013 | 01:02 PM
Try to disconect purple wire from starter solenoid , if solenoid is faulty it can backfeed power to ignition coil .
babalu is offline
Old 10-23-2013 | 09:45 PM
I did not remove or put the engines in, and I did not run it this is the feed back from the mechanic, who installed (of course he tells me this after I brought it home) if he gives me a line of crap then I kick him off the boat and it looks like I am doing it myself (I anticipate kicking him of the boat) hard to get good mechanics these days...normally I do this my self , but with the weather change coming and work schedule I taught Id job the install out OOPS, thanks for all of your help everyone
unfortunately the lanyards are missing
Old 10-25-2013 | 12:36 PM
alternator wired wrong.
dereknkathy is offline
Old 10-25-2013 | 01:57 PM
here is more info, from what was found last night
Port Engine
What started the issue is with a start box (hand held run switches) the engine would start and run, but will not shut down without disconnecting the ignition module
What I saw yesterday .................
With the key in ON position
The power appears to be dead to starting solenoid (0 Volts) and gage group appears not to be energized
With the key OFF position
The power appears to have 12.7 volts at the coil
This would explain a battery draw when the switch is off
With the key in either position the starter dies not activate the starter
I do know that the ignition was not wired backwards as it is the same as the one nex to it, and this condidtion did not occour prior to pulling engines
Old 10-25-2013 | 02:06 PM
Steve H's Avatar
artselectricinc.com
Port Engine
I am almost sure that you have a ground issue. Look under the engine for ANY wires that are not connected. Odds are that the dash is not getting a good ground from the engine or negative side of the battery. If nothing obvious is seen, try running a temporary ground wire to a known ground circuit under the dash.
Let us know how you do
Steve
Steve H is offline
Old 10-25-2013 | 02:17 PM
color match and pin locate the engine harnes to the big connector, follow thru to terminal end. he may have the wrong wire going to the wrong place energizing the ignition
phragle is offline
