525sc upgrades???
Old 10-24-2013 | 05:04 PM
Default 525sc upgrades???
Looking to get some more power out of the motors with reliability in the mix. Had the lower end done over the summer. new cam rods block etc. Still got the bravo xr's. So I may be limited. Suggestions??? (Intercoolers, bigger blower w dual carb set up)
apache88 is offline
Old 10-24-2013 | 05:26 PM
Did you keep the comp ratio stock at 7.5:1??? If so, you can easily change to smaller top pullies and bump the boost up to 7# or more, that is if you can find some smaller pullies.
Switching to a 250 blower will also add some HP and you could run about 7# of boost. You can still run the single Dominator carb.
Did you change/upgrade the cams?????
Griff is offline
Old 10-24-2013 | 05:29 PM
Gary864's Avatar
Becareful of the drives.
Gary864 is offline
Old 10-24-2013 | 06:02 PM
Compression ratio is the same. Upgraded to comp hydr roller. Is the bottom end pretty much maxed out... all upper end stuff??
Any suggestions for drives as well??
apache88 is offline
Old 10-24-2013 | 06:12 PM
The XR drive will be fine as long as you treat it decent. I had almost 300hrs on my Imco upper and stock Bravo lower behind my hopped up 525SC making around 575 hp and it was still going strong.
The bottom end is plenty strong enough for 650hp+.
Griff is offline
Old 10-24-2013 | 06:13 PM
Go with bigger blowers. 420's, 8-71's, etc.
MILD THUNDER is offline
Old 10-24-2013 | 06:16 PM
PSI's or 1471's???
endeavor1 is offline
Old 10-24-2013 | 06:20 PM
Originally Posted by endeavor1
PSI's or 1471's???
PSI's for sure!
Old 10-25-2013 | 09:28 AM
ok thanks guys will start shopping around and getting some pricing
apache88 is offline
Old 10-25-2013 | 09:33 AM
bigboat28's Avatar
How fast is your boat now?
bigboat28 is offline
