Amplifier/ Distribution Block Pictures >
Old 10-28-2013 | 04:41 PM
Default Amplifier/ Distribution Block Pictures
I'd love to see everyone's amplifier installs, particularly boats with 4-5 amps. Mostly looking for distribution block set ups for power and ground wires for amps. I'm going to be installing 4 JL MHD 600/4 amps in one of my boats this winter and just want to get some ideas. Thanks!
PremierPOWER is offline
Old 10-29-2013 | 01:45 AM
Thats a lotta amp. That will power 32 speakers!!!!
Griff is offline
Old 10-29-2013 | 02:19 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have a version of this in my boat. It works very well for part of my setup directly powering 3 amps, 500, 500, and 800.
http://www.rockfordfosgate.com/products/details/rfc10hb
[ATTACH=CONFIG]511241[/ATTACH]
Attached Thumbnails Amplifier/ Distribution Block Pictures-rfc10hb_1_m.png
Sydwayz is offline
Old 10-29-2013 | 11:04 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
http://www.powerboatlistings.com/photographs/24995
Your feet will tingle from the floor with the subs pounding! This stereo played full bore for 2 days solid in Harmon creek this summer with out needing the batteries charged.
US1 Fountain is offline
Old 10-29-2013 | 11:05 AM
16 channels. 12 JL M770's and two JL M10 subs
Old 10-29-2013 | 04:44 PM
Are you going to stack the MHD's? if so maybe you can have a solid busbar made to feed the power to the amps and then just connect the power cables to the busbar, obviously the + will need to be insulated. Also have you considered the M880's? They blow away the M770's I have both in my boat. You should use the MHD750/1 for the subs also. Which one of your 6 boats is the system going in?
pstorti is offline
Old 10-29-2013 | 07:58 PM
Nightlife1970's Avatar
You can't see my distribution blocks they are installed behind the panel the amps are mounted on.
Nightlife1970 is offline
Old 10-29-2013 | 09:10 PM
tomtbone1993's Avatar
I would lurk on the wakeboard forum, I am a member on wakeworld.com those guys all stack the amps and do some cool stuff with wetsounds. Sound Check cig is one of my favorites....
tomtbone1993 is offline
Old 10-29-2013 | 10:12 PM
What batteries is he using?
Pokher Ace is offline
Old 10-29-2013 | 10:18 PM
Batteries?? I think he got a good deal on a slightly used nuclear powerplant from japan.........
phragle is offline
