Fuel consumption - merc. 502?
Does anyone know the fuel consumption on a merc 502 at cruise speed contra full speed...? The boat is a 25 feet scarab and everything runs great except for the fuel gauge... 2 times I've ended up getting towed to the marina by nice people... both times I was sure the fuel would be enough for the trip...
30 GPH? You are talking twins right?
I have a 454 Mag in a '24 Superboat and at 3500 RPM I average about 10 GPH. With a 502 and your boat is probably a little heavier than mine I would guess maybe 15 gph.
that would be for a single 502 magnum,i always thought that this boat was a pig.baja 27'dry , it weighs 4400 lbs.i would also like to hear from others to see how much fuel they burn.it always seems that i am re-fueling .engine is stock except for a holly carb that i installed.
Hey Mark,
I would say that your gas consumption sound high. The MPI motors are probably more fuel efficient. My boat weighs about 3500lbs. It also has a 7' beam. I can cruise at 50 mph all day long on about 10 GPH.
Dave M.
Dave M.
I run a 242 Formula w/ 502 cruise alot (long distance) and with hydromotive quad and RPM about 38 to 4 I burn 16 gallons a hour
If they smile when you pull up to fill up you must be doin it right
Rocket
Rocket
