496 Eagle steel crank, Eagle H-beam rods and Srp pistons
Posting this for a friend. Complete Eagle Gen V 496 rotating assembly. Can be used with gen VI also. Its internally balanced. The parts have less than an hour run time. Motor was fired 3 times and shut down. Was built by a shop and installed in a boat, then sat for 10 years. Condensation got into cylinders through open exhaust valves, creating cylinder rust. Customer brought motor to my buddy to freshen up, and after finding the rust, and needing a new block, customer went with a bigger motor. All the parts are good, but have some surface rust. None of the machined areas are rusty. I would pull rods and pistons apart and clean, then reinstall with new rings and bearings. It is an all Eagle 4340 kit. Internally balanced, h beam rods, and srp (0.60 over) pistons. It was originally for a pro-charged 496 boat.
Asking $1300
Prefer not to ship! Parts are in Antioch, Ca 94509
Scott: 925-998-1517
Mark: 925-250-9428
http://i986.photobucket.com/albums/a...ps70709395.jpg
http://i986.photobucket.com/albums/a...ps445acd83.jpg
http://i986.photobucket.com/albums/a...ps6ba7cbe7.jpg
http://i986.photobucket.com/albums/a...ps7a6e4449.jpg
Asking $1300
Scott: 925-998-1517
Mark: 925-250-9428
