Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Engine compartment Stringers  89 Panther >
Old 11-02-2013 | 08:45 AM
Default Engine compartment Stringers 89 Panther
Has anyone had a problem with 88-90 Panther Stringers cracking? They are not very stought to begin with! Not wet, just cracked! They don't look heavy enough to begin with! I was thinking of taking out conpletely, glassing/ bedding in 5/8" marine plywood and adding 2.5" stringers on top. The other problem is it appears that there isn't a lot of room from the bottom of the bilge to the oil pans! Looking for fixes.
TomR is offline
Old 11-02-2013 | 10:09 PM
glassdave's Avatar
Neno the mind boggler
do you mean you want to glass plywood as a core on the bilge floor and then put stringers on top of that? if so definetly don't do that, if you want a stable core you will need baltek or divinycell or something along those lines.
what do you mean there is a lot of room between the bottom and the oil pan? this distance is directly related to X dimension and fairly irrelevant to everything else. there really is no proper or set distance here.
08 OPA High Points Champion
glassdave is offline
Old 11-03-2013 | 08:12 AM
What I meant is there isn't a lot of room. Although I don't think it's as tight as I said. I actually took a couple of pics before I pulled the motors and I do have some room. That being said, there isn't any sign of a problem on the outside of the hull, it's strickly the stringers. What would be your approach to fixing the hull ?
TomR is offline
Old 11-03-2013 | 10:46 AM
glassdave's Avatar
gotcha' yea i think most are about the same as far as room under the motor. X dims are generally within a certain range so its kinda dictated.
Stringers are far easier to just surgically remove and replace then ryng to repair most times plus you have better control over results. I would zip them out with a multi tool and pop some new ones in made of laminated 3/4 glassed in with three or four layers of 1708.
Old 11-05-2013 | 06:49 PM
Thanks Dave. The bilge is all cleaned up and hardware stripped. I'm going to exactly what you just said, but make them a little more "stout" than what was there!
TomR is offline
