88 Baja resin type?
cheapest they can find unfortunately..you can go over it with vinylester,,it will be stronger,less stink and if mixed rite you will get more working time..
A quote from Steve1
"If one looks at the physicals you will find the Vinyl Ester at nearly twice; Example on Tensile strength the polyesters are say 6000 (resin crumbles before glass is fully loaded) and the Vinyl Esters are around 11000..Also little things like secondary bonding a big Plus there.. But there is a drawback they cost nearly twice also. For the Better resins.
Elongation was mentioned before; the more sophisticated resins more closely match glass fabrics in this area. Also HDT is better and shrinkage is much less... "
uscomposites.com has a nice VE that wont break the bank
08 OPA High Points Champion
