Gil offshore dry exhaust prices?? Who else makes a better system for less??
I have had two sets of Gil dry exhaust on both motors of my boat for a total of 160hrs, and have had two internal leaks on the manifolds which leaked water into both motors, i saved them both, but do not want to go through the chocolate milk experience again!!!! I spoke to Corsa/Gil and they gave me a price of 900 per set for the manifolds and 1525 per set for the dry pipes for trs......is this a deal?? if not, are there any other alternatives?? thanks!!!
Wait a second here.....Anyone else have this problem with them??? I just bought a set and put them on my NEW blower motor....I really don't want to screw up the 17 g's I just dumped into this motor!
By the way, they sound f*ckin AWSOME!!!!
A buddy of mine has 1997 HP500's with the Gils made for mercury and he had 150 hrs on them and had a manifold go bad on both! Luckily, he suspected something was goin wrong and he replaced them with Stainless Marine Manifolds from Brownie before he had chocolate milk for oil!
MD
MD
tank-i have only heard great things about the system.......don't worry about yours!!!!! its just that once in a blue moon you might have a problem......believe me i have had them all!!!!!
kaama-whats a p-1000??
the gils I just took off were installed in 91 salt water use only..not too sure on the total hours..they finally started leaking..pinholes due to corrosion..not a bad record...but am going back with Stainless marine set-up..
upon checking the gil pipes for possible reuse or sale I found 2 small leaks at the weld where the inner and outer pipe are welded to the flange...I cleaned the welds up and was very suprised to see how thin the material was at the weld....kinda scary when that's all that is separating your engine from certain death....that weld was a little cold lapped...
The P-1000 exhaust manifolds were originaly made by Hardin Marine. Each manifold has a plate on it that says "Hardin Marine" but you could also order them from Hardin with just about any name on it. I have seen other marine companies names on them such as Hawk, KAAMA and some others. These manifolds were very different looking manifolds. The jacketed manifold was cast with aluminum, the 3.5" tail pipes were a double wall dry exhaust and they made power gains comparable to a Gil exhaust system. I highly doubt these are still being made as I have not seen any advertisements for many years now. Hawk used to offer them on their engines back in the early to mid 80's. I remember seeing them on their Hawk 511 engine package. KAAMA offered them on their engine packages as well. A friend of mine used to have them on his 30' Scarab.
