509ci Big Block Chevy Long Blocks Dart Heads, Carrillo, Venolia, etc >
Old 11-07-2013 | 02:20 PM
Default 509ci Big Block Chevy Long Blocks Dart Heads, Carrillo, Venolia, etc
509ci Big Block Chevy Long Block Engines (2 Available)
GMPP Bowtie Block - 4.5” Bore – Siamese Bore
Forged Non Twist Cranks – Standard – Not Turned Down
Carrillo H-Beam Rods
Venolia Forged Flat Top Pistons
The following parts were installed BRAND NEW with less than 75hrs
Speed Pro Plasma Moly File Fit Rings
Clevite H Series Main and Rod Bearings
Dart PRO1 CNC 335cc Aluminum Heads with Inconel Exhaust Valves
ARP Head Studs
Cometic MLS Head Gaskets
Howards Race Series Hydraulic Roller Lifters made by Morel
Comp Cams Camshaft .612” Lift
Cloyes Hex-a-Just Double Roller Timing Set
Manley Pushrods
Crane Gold Roller Rockers
High Volume Oil Pump
Gil Offshore Oil Pan
Fluidamper Harmonic Balancer
Flywheel with new ring gear installed
Engines were completely dissembled, cleaned, checked, and freshened less than 75hrs ago. At that time new Dart CNC heads and all new valve train was installed. All hours were very easy hours on a small lake, fresh water use only. Engines were recently removed from the boat and had a leak down test performed. All cylinders were 76-78 out of 80, filters were cut open and no sign of any metal was present. Engines ran fantastic at all times with zero issues. Sold as-is. Asking $8500 each. Will consider selling short blocks also.
x454gtox is offline
Old 11-07-2013 | 02:26 PM
carter38's Avatar
Send pics to [email protected]
carter38 is offline
Old 11-07-2013 | 03:42 PM
Send me pictures to [email protected]. Thanks
danny4pr44 is offline
Old 11-07-2013 | 10:57 PM
Pics sent. Thanks.
x454gtox is offline
Old 11-08-2013 | 09:51 AM
Irishtornado is offline
Old 11-08-2013 | 05:00 PM
Pics please, [email protected]
Alex is offline
Old 11-10-2013 | 08:32 AM
Payton's Avatar
Charter Member #927
Where are you located? Please send me pics as well. [email protected]
Payton is offline
Old 11-10-2013 | 08:43 AM
Were these setup for blowers with the flat tops and 121cc heads? Somwhere around 8.5:1 to 8.75 compression?
MILD THUNDER is offline
Old 11-10-2013 | 01:54 PM
Pics sent. I am located in Idaho. Yes the motors were set up for blowers. I was running b&m 420s one them at about 4-5 lbs of boost. Ran great and very reliable. I am guessing compression with the dart heads to be a little under 9:1.
x454gtox is offline
Old 11-10-2013 | 04:37 PM
Sandpoint or Coeur d A'lene?
hoodoo is offline
