Bravo XR oil leak
Old 11-09-2013 | 08:48 PM
Default Bravo XR oil leak
Last time I took my boat out notice my outdrive was low on oil so I topped the oil fill up. Now it's sitting in the garage an noticed some oil on the ground. Drained some an there wasn't any trace of water. I checked it again this evening and noticed it's leaking from where the upper and lower meet. Also noticed some oil around one of the bolts that connect the two. Didn't have time to look into it more but could it be as simple as a loose bolt? Seal between the upper and lower? Or is something else going on that's forcing the oil out? I do all my work myself to my boat. Not had any outdrive problems so I don't know much about it. Just what I've been studying on here. Any suggests will be appreciated.
jtbooten is offline
Old 11-09-2013 | 09:53 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Re-torque your bolts and see if it stops . If not then probably a bad o-ring . Just get a lower mounting gasket kit and make sure you oil the o-rings before assembly which I'm sure you already know . It's a simple operation .
the deep is offline
Old 11-10-2013 | 06:28 PM
Thanks for the advice.
jtbooten is offline
Old 11-11-2013 | 01:39 AM
I would do as the deep said.
Worst case is you will need split the upper and lower and reseal. Its easy to do without even removing the drive.
Griff is offline
Old 11-11-2013 | 05:03 PM
if you end up splitting the lower from the upper be sure to replace the quad ring with one from your merc dealer,dont substitute it with anything else as it will leak,also when you change it clean any gasket sealer that might have been applied previously.
mike tkach is offline
