Valve Covers.. >
Valve Covers..
Valve Covers..
Old 11-15-2013 | 04:22 PM
Default Valve Covers..
Going to upgrade to roller rockers this year on my 502...but need valve covers to clear them. What covers do the hp500 use? Do they just use spacers on the factory covers? I like the looks of the factory covers over aftermarket ones..
stlliberator is offline
Old 11-15-2013 | 05:36 PM
the roller rockers should fit under your valve covers.
mike tkach is offline
Old 11-15-2013 | 07:54 PM
scottw's Avatar
I have the same valve covers. Wouldn't clear the roller rockers on my engine build. Got these http://www.diamondperformanceparts.c...3&cat=0&page=3
scottw is offline
Old 11-15-2013 | 09:20 PM
Tinkerer's Avatar
The stock covers WILL fit. You may have to remove the drippers - Roller rockers won't need them.
Tinkerer is offline
Old 11-16-2013 | 06:28 AM
scottw's Avatar
I removed the drippers on mine and still would not clear my Crane Golds. I guess it depends on the application.
scottw is offline
Old 11-16-2013 | 08:05 AM
my factory ones clear my crane golds with no issues...
ezstriper is offline
Old 11-16-2013 | 08:34 AM
what year 502...has the cam been upgraded
motor is offline
Old 11-16-2013 | 08:43 AM
you need to do some grindind on 2 of the rocker arms,that is what mercury does.
Old 11-16-2013 | 09:56 AM
Its a gen 6 502..yes the cam has been changed..it has the different timing set in it, and retro fit roller rockers.
I have already ground down the rockers..
Old 11-16-2013 | 10:05 AM
Do you have the cam specs
motor is offline
