Cam? Teague stage 2 = Crane 741  ?? >
Old 11-17-2013 | 11:06 AM
Default Cam? Teague stage 2 = Crane 741 ??
Looks like the Teague stage 2 cam is the same as the Crane 741. Can anyone confirm if this is the case?
http://teaguecustommarine.com/stage-...aft-26914.html
dandercam1 is offline
Old 11-17-2013 | 11:45 AM
the specs are the same,crane has 2 different part numbers,1 is for mark 4, the other is a bullet nose for a retaining plate [gen 6]
mike tkach is offline
Old 11-17-2013 | 11:48 AM
The Teague cam has 4* less advertised duration on exhaust and 2* less on intake. Lift is the same.
Griff is offline
Old 11-17-2013 | 12:08 PM
+1.
MILD THUNDER is offline
Old 11-17-2013 | 01:11 PM
Same as the crane 139021 I think.
fbc25el is offline
Old 11-17-2013 | 01:13 PM
I have a Teague Stage 2 available, just removed from 90 hour 540 if interested.
launchpad475 is offline
Old 11-18-2013 | 02:23 AM
Ok found the Crane 741 can still be had over the counter at summit. Don't know why I didn't look there first.
http://www.summitracing.com/parts/cr...make/chevrolet
Also looking at the Comp 01-456-8. looks like a little more aggressive ramp but less lift. Given the price I am guessing a much lower quality cam blank. Anyone ever try it?
http://www.summitracing.com/parts/cc...make/chevrolet
I am thinking about a build on my 502's. Plan is looking like 9.5 c/r and leaning towards RHS 320 aluminum castings with the ports cleaned up a bit, already have Brodix HV 2000 intakes with 850 holley carbs and EMI long riser exhaust. I have read allot of old posts where guys are running the Crane 741 with GM lifters. Sounds like the earlier Gen.V lifters might have been shorter than the newer Gen VI lifters so I plan on seeing how everything actually works when it is in the block before making the final decision.
