Looking for Hydraulic new or used TRS >
Old 11-17-2013 | 07:19 PM
Default Looking for Hydraulic new or used TRS
I am Looking for Hydraulic new or used TRS for my 357 SR 1. The boat had an inside mounted rams. I am not looking to "drill and fill" any holes if I can help not to. It seems to be a Latham Marine set up but I will need to check the mounts for the hull. I am looking for a full set up . Thanks Jim
jim8860 is offline
Old 11-17-2013 | 08:10 PM
that boat did not have latham style .it had the non power assist style witch was removed and sold .i do have everything you would need to put the internal steering back in it though ,the holes in that are an easy fix if you use dowels coated i resin .glad to see its going back together
smokin' gun is offline
Old 11-17-2013 | 09:13 PM
I guess you were the old owner ?.....
jim8860 is offline
Old 11-17-2013 | 10:23 PM
Bilgerat's Avatar
I have both a full AIr over Hydraulic Hynautic system, and also can get an old I believe Mercury system from a 12 meter fountain. Shoot me an email for pics. [email protected]
Bilgerat is offline
Old 03-24-2014 | 07:00 PM
Are you still looking?
hydrostream is offline
Old 03-24-2014 | 07:16 PM
O.C.Barry's Avatar
Smokin' Gun is correct, the boat had Marine Machine, non-power assist hydraulic steering. I didn't own the boat, but it belonged to a good friend.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 03-24-2014 | 07:20 PM
O.C.Barry's Avatar
[ATTACH=CONFIG]520873[/ATTACH]Here's a picture:
Thanks, Barry
