Think I found my graphics?? >
Old 11-25-2013 | 10:24 PM
Default Think I found my graphics??
Ok, its a 36ol at pier 57 and I'm digging it! I need to keep my teal for interior. Blue, teal and yellow! Looks good!
Whatcha think? Maybe not running the upper lines all the way up front and change up a little to match the teal graphic lines on my sunpad.
[ATTACH=CONFIG]513170[/ATTACH][ATTACH=CONFIG]513171[/ATTACH][ATTACH=CONFIG]513172[/ATTACH]
Attached Thumbnails Think I found my graphics??-image.jpg   Think I found my graphics??-image.jpg   Think I found my graphics??-image.jpg
nailit is offline
Old 11-28-2013 | 05:59 AM
like them. But that wont cover yours??
mittens is offline
Old 11-28-2013 | 07:32 AM
Paint or wrap?
502ss is offline
Old 11-28-2013 | 08:46 AM
Not sure, depends what I can scrape together and if we get bonuses in spring :-)
Would like paint but would wrap also.
Mittens, why you think it wouldn't cover?
nailit is offline
Old 11-28-2013 | 09:14 AM
Go for paint if you can!!! Doing a lot of the prep work yourself can save you some coin!! If you went this route wouldn't you have to change your interior??
T-RAV is offline
Old 11-28-2013 | 09:28 AM
[ATTACH=CONFIG]513302[/ATTACH]
90% of interior is teal. So would use teal on the side to coordinate. Only pink in interior is where the bolster meets the plastic on hand rail and can barely even see it. It was all replaced at some point (vinyl) and n great shape, so not planning on replacing. Eventually, I could match the hull better when the time comes.
nailit is offline
Old 11-29-2013 | 03:55 AM
I just think the line from your factor graphic would be in between the new lower and new upper graphics.
mittens is offline
Old 11-29-2013 | 08:19 AM
oh... I think I see what you mean, no... I would cover the whole side if wrapped.
I would change the green in the pic to Teal instead, then I would probably end the teal stripes at the windscreen or hatches instead of running it all the way to the front. Would still have to wrap the whole thing to the bow to cover the existing stripe.
I did think about wrapping just above the existing stripe though... its only 17' to the leading edge of the pink in current graphic but didn't know how ending the wrap there would transition?(white wrap to white gel)... would be cheap though!!
nailit is offline
Old 11-29-2013 | 09:08 PM
I like the graphics. But not above the rub rail and not up onto the windscreen
Doughboy is offline
Old 11-29-2013 | 09:53 PM
Agree, definitely don't like on the wind screen and if it were only the blue above it would look OK, but fading the yellow up too high. Would look better with it below! I would probably swap the green and blue and change the green to teal to match my interior and platform. Then I wouldn't run the blue (current green in pic) to front along rub rail.
nailit is offline
