84" Apache Warhawk
I finished this a while back and I am now selling it to fund another project. It is a 84" Apache designed like Warhawk.
It has a full Mod K600 with 257 carbs(maybe a half gallon thru it), Zipkit Stainless Pipes and headers with carbon mufflers, RCMK clutch, T-bar for the stuffing, Accutech strut assembly with 2" composite extension, Custom design rudder system using Speedmaster hardware one rudder feeds the water pumps for the engine case and cylinders, the other rudder feeds the exhaust manifolds, Bonzi trim tabs, accutech large turn fin, the tie bar that connects the rudders together is Titanium, I also machine some composite blocks for the 2" extensions for the rudders with out these the rudders did not look correct, two auto bailers, Dual water pumps and I drilled and tapped the aluminum intake manifolds for the pulse source for the pumps, The servos are Hitechs, Digital 1/4 scale for the rudders and MG-645 for the throttle, Voo-Doo 30/16 two blade stainless prop, 1000 ML Iv bag feeds both carbs. The custom paint job is very nice and and designed off of the real Warhawk Apache. All you will need is a transmitter and receiver and your set to go. It starts extremely easy and idles perfectly until you are ready to hit the gas. The sound is amazing!
This boat runs extremely well and turns like it is on rails, I set the CG up at 27% and I don't think you could get it any better. It is by far the best running big 84 RC Apache that I have seen on the internet. $4800 shipped in the 48 states and i will crate it up and ship it Fedex Freight to a commercial address.
Thanks for looking,
Aaron
Thanks for looking,
Aaron
this thing is beyond cool!!!
[ATTACH=CONFIG]513199[/ATTACH][ATTACH=CONFIG]513200[/ATTACH][ATTACH=CONFIG]513201[/ATTACH][ATTACH=CONFIG]513202[/ATTACH][ATTACH=CONFIG]513203[/ATTACH][ATTACH=CONFIG]513204[/ATTACH]
