how much boost??? >
how much boost???
how much boost???
Old 11-26-2013 | 08:37 PM
Default how much boost???
Motors started as hp500s. Standard stroke, bored for 509". Inverted dome for 7.6:1 static compression. Stock heads. 525 efi cams, H-beam rods, main studs, arp head bolts, 420 mega blowers with super chillers. Pullies i have are 17% overdrive. What would i expect out of this combination or do a look for bigger upper pullies?
Rbesola is offline
Old 11-26-2013 | 11:14 PM
I would probably start with the 17% overdrive and see where it puts you. What size pulleys do you have now for top and bottom?
With 7.6:1, GM rect port heads, 420 blower, your real close to what the merc 600SC was, except for cam. I wouldn't hesitate to run 8psi with the intercooler, maybe more. DMOORE on here, had a stock 600SC, added a chiller, cranked the boost to 10psi. Engines been running that way for a looooong time.
MILD THUNDER is offline
Old 11-26-2013 | 11:15 PM
Speaking of which, did you ever find intakes?
Old 11-26-2013 | 11:18 PM
Red face
^^^^ He is building them, didn`t you see the pics on facebook today?
ICDEDPPL is offline
Old 11-26-2013 | 11:22 PM
No, Ill have to check it out.
Old 11-26-2013 | 11:27 PM
a long time ago i had a similar setup but no inncrcooler and i ran 8 lbs boost,blower was a bds 8.71 it is slightly bigger than your 420,it was in a 27 ft cig copy.i ran it hard for four years,then put it in a 18 ft sanger and beat it for 2 more years then sold it.never had a problem.
mike tkach is offline
Old 11-26-2013 | 11:31 PM
We are always on the same page
Old 11-26-2013 | 11:40 PM
Yes we are.
Old 11-27-2013 | 10:27 AM
What fuel are you running?
ThisIsLivin is offline
Old 11-27-2013 | 12:32 PM
I ended up milling my tall decks down. Plenty of meat left them.
And i don't remember the sizes off hand but I've got it written down somewhere. It came out to 17.1something.
Glad to hear the positively on the reliability aspect of my build. That's my main goal!
Rbesola is offline
