Winter Project - Trim Tab Gauges >
Old 11-27-2013 | 09:58 AM
Default Winter Project - Trim Tab Gauges
I have a 1989 Formula 242 SS with the stock Bennett trim tabs and I would really like to install the trim tab gauges that show their position.... Has anyone every done this project? Is it a difficult job? Worth it? Advice?
I have no idea what it even entails just yet...... figured I would get the advice of some Formula owners first.
Thanks in advance...
DRock is offline
Old 11-27-2013 | 10:16 AM
inicators would be easier than gauges I believe... heads up indicators for my lencos are on the winter list.
phragle is offline
Old 11-29-2013 | 05:38 AM
Mechanical indicators would be best. Do you have a mechanical indicator for the outdrive?
tpenfield is offline
Old 11-29-2013 | 10:04 AM
I used the Lenco switch with led indicators on my Donzi and they worked perfect. Easy install and all done at the dash.
Katanna is offline
Old 12-10-2013 | 06:51 PM
Bennett Tab Indicator #TPI2000
http://www.bennetttrimtabs.com/catal...?vID=196&cID=2
JBmarine is offline
Old 12-11-2013 | 12:16 PM
eBay Bennett eic5000 comes with meters for rams, wiring, a new led indicator with control buttons and a automatic retract when ignition is turned off. About $335 delivered if I remember correctly. I think I will go this rout.
befu is offline
