Go Back  Offshoreonly.com > General Discussion > Offshoreonly Industry News
Livorsi Marine - Request Your Livorsi Volume 18 Catalog >
Old 11-27-2013 | 05:08 PM
KennyOffShore's Avatar
Administrators
Default Livorsi Marine - Request Your Livorsi Volume 18 Catalog
Products Include
Electronic Sidemount Controls
o Two versions have been created to fit a wide range of applications:
o Fully Electronic - Electronic Throttle and Electronic Shift
o Hybrid - Electronic Throttle and Mechanical Shift
o The new ski controls allow for a smoother and safer ride with lightning fast shifting and throttling at your fingertips
o Click here to read more
Gussi Steering Wheels
o Several new styles available
o Fits 3/4" rounded tapered shafts with keys
Livorsi DTS Controls
o Livorsi Smartcraft® Digital Throttle & Shift (DTS) controls provide smooth and safe shifting.
o Designed to work on all Mercury DTS equipped engines:
o Verado 150 - 350 SCI
o Mercruiser 5.0L - 8.2L
o Optimax 225
o Mercury Racing 565, 1100, 1350
o and Cummins engines that are DTS capable
Vantage View® CAN Bus Gauges
o Vantage View® CAN Bus instruments display all the information your engine’s ECU provides
o Designed to work with any SmartCraft®, NMEA 2000® or SAEJ1939 engine
o This series features: programmable alarms, faults and warnings, pop up alerts, fuel tank and engine trim calibration and more
LED Position Indicators
o These indicators can eliminate the need for mechanical 33C cables which are typically used for drive and tab indication
o With the Livorsi LED indicators, mechanical cables are replaced by more reliable network wiring that allows ‘plug n play’ connectivity into existing tab or drive position sensors
o Capable of reading CAN Bus protocols such as SmartCraft® (with Gateway), NMEA 2000® and J1939, as well as 0-5 volt or resistive-type (ohms) inputs
Please note, that due to high cost of printing, we must charge customers a $10.00 fee per printed catalog. But don't worry, this fee will be refunded on your next order with Livorsi Marine.
If you would like a copy of Volume 18, please call 847.752.2700.
KennyOffShore is offline
HTML code is On
