What hydraulic roller cam to use in place of this solid roller cam in my 598's? >
Old 11-27-2013 | 08:38 PM
Default What hydraulic roller cam to use in place of this solid roller cam in my 598's?
So I have a pair of chief 598's, with 10-71's, super chillers, low boost 5-7 psi. 900ish.... Hp. Very low hours, fresh, running excellent. But I would like to convert them to hydraulic rollers, from the solid rollers they are now. Don't plan on ever spinning them past 6k. Can someone recommend a cam grind, spring, and lifter combo that would duplicate my current power level, but in hydraulic form?
Attached Thumbnails What hydraulic roller cam to use in place of this solid roller cam in my 598's?-image.jpg
rob vanharten is offline
Old 11-27-2013 | 09:06 PM
rv
What rpm does it idle at out/in gear?
Shift in/out of gear ok without stalling? Big props?
rv is offline
Old 11-27-2013 | 09:11 PM
Originally Posted by rv
What do you idle at?
Right now they surge from about 800 to 1400 rpm. They shift in and out of gear excellent. If I lean out the idle circuit they won't surge, but die as soon as I put them in gear. I kinda like the surge anyway. Yes big props, 37 pitch 17.5 diameter, 18 degree rake.
Old 11-27-2013 | 09:43 PM
Rob It has been a while since I've looked into Hyd. Rollers but I'm not sure you will be able to replicate that type of aggressive cam in a hyd roller. but there are many others with more knowledge in that area than me. I hope they will chime in on this. But I bet that motor sounds real strong!
abones is offline
Old 11-27-2013 | 09:59 PM
Originally Posted by abones
Rob It has been a while since I've looked into Hyd. Rollers but I'm not sure you will be able to replicate that type of aggressive cam in a hyd roller. but there are any others with more knowledge in that area than me. I hope they will chime in on this. But I bet that motor sounds real strong!
Yes these motors sound really nice . I have been talking with some other people and they have said this should be no problem with today's hydraulic rollers... Just trying to figure out the correct recipe!!
Old 11-27-2013 | 10:15 PM
i can pm you with the cam specs in my 588,s if you would like but i recommend calling bob madera,he is up on all the latest products and is very good at picking a cam for any application.i know someone who got a price from bob and then called to compare prices,he bought from bob.
mike tkach is offline
Old 11-27-2013 | 10:33 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Bob Madara is OSO's cam and valve train guru . Best of all he is a very honest man as well as being very intelligent . 585-654-8583
the deep is offline
Old 11-27-2013 | 11:20 PM
Hydraulic roller in my 598 is 250 258 @ .050 .696 .680 lift I run the morel high rpm lifters. The lifters will go to 7300 rpm they do like some spring pressure 200-225 closed 500-550 open. Oil can't be any thicker than 10w40. I run 30 weight and run the piss out of it with no issues so far. I tried to run these lifters on a solid roller cam when it was first put together and it did not work having preload in the lifter hung the valves open and the motor made no compression. If I set them at zero lash it would run like a champ. Zero lash on a hydraulic lifter in a boat probably not a good thing...
Black Baja is offline
Old 11-27-2013 | 11:30 PM
Craney's Avatar
Originally Posted by the deep
bob madara is oso's cam and valve train guru . Best of all he is a very honest man as well as being very intelligent . 585-654-8583
a+
Craney is offline
Old 11-28-2013 | 01:13 AM
KAAMA's Avatar
If you pick Bob Madara of Marine Kinetics, then you will have picked the right guy for your cams....when it comes to marine cam specs for a certain application, Bob has been the "go to guy" for many years here on OSO....and he's a very smart dude.
KAAMA is offline
