dry sump conversion
For those of you that are dry sump engines. What oil tank are you using? I'm not seeing many choices for marine use. what tank has proven itself for extended WOT marine use. I have a 4 stage pump and prefer not to use a manifold. Also what capacity are the tanks you guys use,thanks.
We are using the STEFF square design tank, 5 gallon capacity. You can search for Cat Can Do/Udderly Fantastic 35 Motion Restoration for pictures of the tanks installed. The system is sealed allowing for pulling over 10" of vac. The tanks are mounted on bulk head brackets providing easy removal for oil changes.
