Standard Bravo Gimbal Transom assembly set-up for XR drive for sale. >
Old 12-14-2013 | 12:44 PM
Default Standard Bravo Gimbal Transom assembly set-up for XR drive for sale.
I have a clean fresh water standard Bravo Transom gimbal assy. for sale. This unit is in very good used condition with just under 200 original hours. It is a 2000 model year with the drive lube monitor bottle. It includes the inner plate. Pins are tight and not messed up. New parts in last 4O hours are ....XR gimbal bearing kit with trim ram spacers, new shift cable, new bellows. One of the trim rams is tight but worked fine when installed on the boat??? The steering shaft seal dripped very slightly (30.00 in parts to fix) and I broke a plastic elbow for the lube bottle when removing (5.00) Bottom 2 studs have corrosion but are not seized in the unit ($16.00) Very good unit at a very good price. $650.00 FIRM I will ship in a original Mercury box for $125.00 (90lbs) Paypal or money order accepted. Thanks,Jeff Wurl
jwurl is offline
Old 12-25-2013 | 11:50 AM
Price drop. $675.00 shipped in the US. Jeff Wurl
jwurl is offline
Old 01-11-2014 | 09:37 AM
Bump. It is still for sale. Jeff
jwurl is offline
Old 01-19-2014 | 09:47 AM
IT IS SOLD . Thanks for the interest. Jeff Wurl
jwurl is offline
