Best bottom wax?
Old 12-15-2013 | 01:47 PM
Default Best bottom wax?
What is the best wax to put on the bottom? Thanks for any input.
Titan907 is offline
Old 12-15-2013 | 02:55 PM
Best answer is most likely no wax.
sonicss42 is offline
Old 12-15-2013 | 03:12 PM
You're kidding, right? You don't wax the bottom.
thirdchildhood is offline
Old 12-15-2013 | 04:45 PM
As others have said- the best wax is no wax!
endeavour32 is offline
Old 12-15-2013 | 05:29 PM
Mrs Mosi's bottom is not that hairy. ....
..... If it bothers you that much maybe you should date women...... or men.....
.... with a different, less hairy, nationality.
IMHO.
mosi is offline
Old 12-16-2013 | 05:46 PM
No wax! Take your hand and wipe it on a car after being waxed when wet. It sucks your hand to it. Some actually wets and the bottoms of boats with 400 grit to create bubbles which in turn causes lift and speed. Crazy I know but works.
Eliminatorshane is offline
Old 12-16-2013 | 06:31 PM
Eliminatorshane-- you comment about the 440 grit is not crazy -- back in the day when I would do a lot more water skiing I would take a scotch pad and scuff the bottom of my EP ski. It sounds crazy but it does work.
I will be honest that I do wax the sides and a good portion of the bow but that's it-- there is something about a shinny boat!
3pointstar
3pointstar is offline
Old 12-16-2013 | 07:45 PM
Unless you are trying to get every mph out of boat ( race ) No wax
But if you don't want a water stain use a marine sealer not a wax
riverboater is offline
Old 12-16-2013 | 08:04 PM
wd 40 to clean the road goo off and thats it..
FIXX is offline
