Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
89 Scarab lll, Transom, Stringer, Paint, .......ect >
Old 12-18-2013 | 10:48 AM
Default 89 Scarab lll, Transom, Stringer, Paint, .......ect
It's my turn to run through the pain/satisfaction of rebuilding the ass of my boat. Check out the pics. You can see just how rotted the exhaust hole is. The 5" tip was put in from the inside and just sealed on the outside. The exhaust flowed through the stock swim platform that has been chopped up as well. I'll post more pics this weekend. What you see here even had mold growing within it, nasty stuff.
I'm starting this thread just to share my experience and to bounce a few questions around when I get stuck on something. I've saved so many threads to walk to through this and there is one particular video on youtube that breaks this down pretty well also. [ATTACH=CONFIG]514470[/ATTACH][ATTACH=CONFIG]514471[/ATTACH][ATTACH=CONFIG]514472[/ATTACH][ATTACH=CONFIG]514473[/ATTACH]
Attached Thumbnails 89 Scarab lll, Transom, Stringer, Paint, .......ect-transom-1.jpg   89 Scarab lll, Transom, Stringer, Paint, .......ect-transom-2.jpg   89 Scarab lll, Transom, Stringer, Paint, .......ect-transom-3.jpg
ramos45 is offline
Old 12-18-2013 | 10:52 AM
Here are some pics of the outside. I'm removing the wrap the PO had on it. Looks pretty good but the graphics went over the swim platform which is now gone. need to figure out how to continue them around the back. [ATTACH=CONFIG]514474[/ATTACH][ATTACH=CONFIG]514475[/ATTACH]
Attached Thumbnails 89 Scarab lll, Transom, Stringer, Paint, .......ect-imag0501.jpg   89 Scarab lll, Transom, Stringer, Paint, .......ect-imag0502.jpg
ramos45 is offline
Old 12-18-2013 | 11:38 AM
Now would be a great time to patch up those old exhaust holes, and run a traditional style thru hull setup with 4 holes.
MILD THUNDER is offline
Old 12-18-2013 | 11:43 AM
That's exactly the plan. I'm ditching that old set up.
ramos45 is offline
Old 12-18-2013 | 12:06 PM
Wow! Pretty big project! Hope the turnout is great! Love these threads!
KRAUSMOTORSPORTS is offline
Old 12-18-2013 | 12:29 PM
I hope so too.
I plan on using 1.5oz CSM, 1708 biax, cabosil, .25" chopped strand, vinyl resin and two layers of .75" ply. This isn't the schedule, it's the list of what I will be using. Can somone recommend how much how much material to order for the job?
ramos45 is offline
Old 12-18-2013 | 02:09 PM
glassdave's Avatar
Neno the mind boggler
for the transom and stringers I would start with a five of VE and roughly twenty five yards of 1708. For CSM 1.5 oz is all you need and you will need approx 8 to 10 yards. you may also want to grab a roll of eight inch tab tape, its a cheap time saver.
You can get a more accurate estimate by measuring everything off and a little math. This is roughly what the layup will consist of (pic), stringers have minimum two layers and two or three layers of tabbing alternated in pending on how heavy you want it. With a good VE and a well balanced (not saturated wet) resin ratio you dont have to over build.
Attached Thumbnails 89 Scarab lll, Transom, Stringer, Paint, .......ect-transom-layup.jpg
08 OPA High Points Champion
glassdave is offline
Old 12-18-2013 | 03:49 PM
scippy's Avatar
Another illustration that's worth a thousand words!
scippy is offline
Old 12-18-2013 | 07:14 PM
jeff32's Avatar
let's follow this!!!
jeff32 is offline
Old 12-18-2013 | 07:30 PM
This can be a great ''How to thread"!
