D... blue drain plugs >
Old 12-21-2013 | 09:33 AM
Default D... blue drain plugs
I have 8 of these, and often they break. This time 2 broke just by being installed, well before any resistance was felt. Luckily I could get both out again. Is this normal? Is there a better solution? Or are these considered wear parts that I should only use once? On ebay, are the $10 Mercruiser better than the others?
I assume that if one of the lower ones break while in the harbour, it'll sink?!
No Quarter is offline
Old 12-21-2013 | 12:59 PM
I get them at local dealer for $6, but sounds like your tightening too much. They have o-rings, so just snug up.
nailit is offline
Old 12-22-2013 | 12:17 AM
Sounds like your threads might be corroded. They shouldn't break that easy.
Griff is offline
Old 12-22-2013 | 12:46 AM
Thanks, I'll clean the threads, by Mercruiser branded plugs, and be more gentle.
BTW, how do I get a picture on my profile???
Old 12-22-2013 | 11:01 AM
Rookie's Avatar
http://www.offshoreonly.com/forums/payments.php
Rookie is offline
Old 12-22-2013 | 04:19 PM
Yea there probably worth replacing every once in a while, you don't need to crank them down, finger tight should be good
BIGBREW is offline
Old 12-22-2013 | 06:05 PM
Ask anyone who winterizes alot of boats they will all break eventually. I would use new ones everyother year.
flat rate is offline
Old 12-22-2013 | 07:26 PM
Yes I learned too they last a lot longer just finger snug. They do eventually break though.
johnny b good is offline
Old 12-22-2013 | 10:13 PM
You could go all brass
http://www.acehardware.com/product/i...631279.2631284
ICDEDPPL is offline
Old 12-22-2013 | 10:26 PM
Randy Nielsen's Avatar
The brass ones will last for ever + no o rings to lose or break but you might have to tweak them with pliers to tighten or loosen them. Randy
Randy Nielsen is offline
