454mpi VI duel in boss 302 putting up have ?????? >
Old 12-21-2013 | 06:30 PM
Default 454mpi VI duel in boss 302 putting up have ??????
Hey guys I have a 99 boss 302 baja w/454 mpi with open cooling system. I am putting the boat up for 2 months and will stored inside... I will not see freezing temps here in sc and I want to know what is needed to be done??? Add stabil to the gas and put stabil in the water/fuel seperators filters so at first start up things will get cleaned??? Pull cooling hose off???? Just a month ago did out drive service and also oil change and filter on both engines. Battery are on tenders in the OFF positions. Please let me get some input from all you expieranced guys!!!))) thanks
Ozziebaja302 is offline
Old 12-21-2013 | 08:21 PM
Nothing.. mine sits from 2-4 months.. I drain the blocks, but really don't need to do anything else unless you put ethanol gas. If so, put stabil or seafoam in the fuel.
nailit is offline
Old 12-21-2013 | 08:26 PM
Nailit, when you say drain the blocks can u explain a little more on exactly what you mean???? Thanks pal
Old 12-22-2013 | 12:15 AM
If you are 100% sure, you don't have to worry about freezing temps, then just put some Stabil in the fuel tank as a precaution and that is not really even needed.
Nothing else needs to be done for a 2 month lay up.
Griff is offline
Old 12-22-2013 | 03:26 AM
+1 Here in Pittsburgh sometimes it just rains for 2 months straight in the summer............I always use a ethanol fuel stabilizer but a 2 month layup has never been an issue at all.
dandercam1 is offline
