Salt on boat/trailer
Old 12-22-2013 | 10:45 AM
Default Salt on boat/trailer
Hello,
I was finally able to put my boat into storage yesterday. On the way from my dealer to storage I picked up some salt on the boat and trailer. I was able to take my towels with clean buckets of water and get the salt of from the sides of the boat and most of the trailer. I even went over the boat with my spray wax. My question is I haven't done the bottom of the boat where the axles are. Will this cause a problem if I can't get to it for a couple of weeks? My boat is in climate controlled storage so it is about 60 or 70 degrees.
Thank you,
Lou
waterman is offline
Old 12-22-2013 | 10:59 AM
Go get some salt away and put is in a spray jug from home depot and spay your trailer down, that should help out.
boating37 is offline
Old 12-22-2013 | 11:55 AM
ratman's Avatar
use speed wax on the hull and salt will never stick to it, plus you will get 20% better gas mileage and another 12 mph top end...
ratman is offline
Old 12-22-2013 | 12:53 PM
The speed wax jokes were funny..............
..................about 5 years ago
Griff is offline
Old 12-22-2013 | 01:25 PM
you only got 12 mph,better wax it again.
mike tkach is offline
Old 12-22-2013 | 03:59 PM
ok heres how it works..if you would have put your boat in cold storage you would have been better off..the salt wont do any damage if the temps are below 32* but since you put it in heated storage i would be all over bpth the boat and trailer with a pressure washer..
just my o2.
FIXX is offline
Old 12-22-2013 | 05:43 PM
I wouldnt worry to much. Are you concerned about you tow vehicle?
flat rate is offline
Old 12-22-2013 | 06:21 PM
Thank you replying. I just came back from cleaning the trailer and bottom of the boat. Everything is good, wasn't that hard to get off. I had two wash buckets, microfiber towels and a wash sink. I'm not sure how durable the paint is on my trailer.
Lou
waterman is offline
Old 12-22-2013 | 06:29 PM
I worry about the tow vehicle.
Guess anal'ness is all in the eyes of the beholder.
Lou
Lou, not very durable in my opinion. If you're anything like me you'll now be able to sleep at night.
TW720HVY is offline
Old 12-22-2013 | 07:03 PM
I use it instead of oil in the motor.
f_inscreenname is offline
