588ci Tall Deck - Complete without Intake - $3,950
Putting it up on here before it goes to Ebayland. Need to clean out the garage... Here are the specs:
Needs reassembly. Priced to move at $3,950. I live just south of Tampa if you'd like to see it.... or I can ship it no problem. Considering ALL kinds of trades... just PM me what you have and we can go from there.
Thanks guys
[ATTACH=CONFIG]515038[/ATTACH][ATTACH=CONFIG]515039[/ATTACH][ATTACH=CONFIG]515040[/ATTACH][ATTACH=CONFIG]515041[/ATTACH][ATTACH=CONFIG]515042[/ATTACH][ATTACH=CONFIG]515043[/ATTACH][ATTACH=CONFIG]515044[/ATTACH]
- 588ci Tall Deck 10.2 Block
- Crower 4.5" crank
- What look to be Carillo Rods (see pictures - no name on the rods but have been balanced)
- JE Bower pistons
- Brodix Big Brodie heads (heads are in great shape - need dipped and valve job)
- ARP Stud Kit
- Crower Stainless Roller Rockers
- Aluminum Flywheel
- Bellhousing with twin trans cooler
- Comes with blower crank pulley and pulley tension system - polished
- Large heavy duty oil pan
- Misc marine items like alternator, power steering pump, etc...
Thanks guys
I literally disassembled the motor and then took pictures of it... so no... it does not look brand spanking new.... I will post more pictures of the top of the heads as well as the head to header side.... no corrosion what so ever. I may also clean the heads before putting up on ebay. Posting this week...
