500 EFI Head Question >
Old 12-26-2013 | 11:30 PM
Default 500 EFI Head Question
I'm looking into rebuilding my 500 EFI, it has about 450 hours on it but still runs like a champ. It has already had new valves, springs, etc.. put in around 200 hours. When I rebuild it and punch it out to a 509, do I need to replace the heads or just have them machined and replace the springs and valves?
Racerngr1 is offline
Old 12-27-2013 | 01:23 AM
Really all depends on your budget. If you don't want to spring for New heads I'd just have them gone through again. If you want to spend the extra and get a little more power then sell your old heads and put it towards the new ones.
Drock78 is offline
Old 12-27-2013 | 01:40 AM
If you are keeping it stock, then just have the machine shop do a valve job, and replace the springs, retainers/locks and guides.
Griff is offline
Old 12-27-2013 | 05:40 AM
Vinny P's Avatar
I hate the winter!!
If its within the budget, replace the exhuast valves. However, if there is any signs of water, you have to replace the exhuast valves. I agree.... if going for a stock rebuild, no need to replace the heads. It may cause more problems than it would be worth.
Vinny P is offline
Old 12-27-2013 | 07:24 AM
$2500 will get you a beauty set of AFRs.
Pismo10 is offline
Old 12-27-2013 | 08:45 AM
Well frankly, I am a boater on a budget. I have a 1 and 3 year old so I'm not trying to build an engine that's going to set the world on fire speed wise, my #1 goal is reliability (turn key). It's starting to get high in hours so that's why I was thinking about doing a good rebuild so I wouldn't have anything to worry about for another 500 hours from now.
Old 12-27-2013 | 10:20 AM
I would just have the heads redone then. Also. .If your cylinder walls are within spec I would just hone instead of boring it to a 509
Drock78 is offline
Old 12-27-2013 | 11:23 AM
One of the guys I was talking to mentioned something about a valve seat falling out if they weren't replaced or something along those lines, does that make sense?
Old 12-27-2013 | 11:32 AM
Just take them to a reputable machine shop, they will tell you exactly what needs to be done.
Pwraddr is offline
Old 12-28-2013 | 11:02 AM
If the heads have been run in salt water for 10+ years it would be a good idea to replace the castings,the salt water eats them up from the inside and can cause the exhaust seats to fall out or get a pinhole,if the budget allows new castings are the way to go,can also get a few bucks for your old ones if still good
MDGperformance is offline
