Tie Bar off XR drives - 32" center-to-center. >
Old 01-03-2014 | 03:26 PM
Default Tie Bar off XR drives - 32" center-to-center.
I have a nice clean tie-bar that came off my boat that did have XR's on it. It is 32 center to center but does adjust some. $150 + Shipping.
[ATTACH=CONFIG]515674[/ATTACH][ATTACH=CONFIG]515670[/ATTACH][ATTACH=CONFIG]515671[/ATTACH][ATTACH=CONFIG]515672[/ATTACH][ATTACH=CONFIG]515673[/ATTACH]
Attached Thumbnails Tie Bar off XR drives - 32" center-to-center.-tie-bar-2.jpg   Tie Bar off XR drives - 32" center-to-center.-tie-bar-3.jpg   Tie Bar off XR drives - 32" center-to-center.-tie-bar-4.jpg
Tie Bar off XR drives - 32" center-to-center.-tie-bar-5.jpg   Tie Bar off XR drives - 32" center-to-center.-tie-bar-6.jpg
TCBoss302 is offline
Old 01-03-2014 | 04:33 PM
How big is the bolt hole?
Keith Atlanta is offline
Old 01-03-2014 | 09:04 PM
Keith, it's 5/8.
Old 01-06-2014 | 08:27 PM
Ttt....Keith?
Old 01-07-2014 | 01:59 PM
Is the measurement at the current set up, meaning you can adjust the width in a little on the one end? Need 31.5 for my set up.
Katanna is offline
Old 01-07-2014 | 07:57 PM
It is adjustable and it appears its adjusted out pretty far. I'll adjust it in and show you a measurement . It very well might get into 31.5".
Old 01-07-2014 | 08:21 PM
I measured again and took pictures with a tape measure. It's 31.75" exactly center to center of bolt holes. There is .75-1" of adjustment showing on threads. Meaning it could easy adjust in to what you need, but may not adjust out greater than the .75-1" if someone needed lets say 32.5". It should work fine for you. I'll post pics in the morning.
Old 01-08-2014 | 11:00 AM
Katanna, Here are some pictures showing how it could easily adjust to 31.5".
[ATTACH=CONFIG]515962[/ATTACH][ATTACH=CONFIG]515963[/ATTACH][ATTACH=CONFIG]515961[/ATTACH][ATTACH=CONFIG]515960[/ATTACH]
Attached Thumbnails Tie Bar off XR drives - 32" center-to-center.-tie-bar-measures.jpg   Tie Bar off XR drives - 32" center-to-center.-tie-bar-measures-1.jpg   Tie Bar off XR drives - 32" center-to-center.-tie-bar-measures-2.jpg
Old 01-08-2014 | 11:04 AM
P M sent
Katanna is offline
Old 01-09-2014 | 07:35 PM
P M sent
Sold, thanks!
