7.3 oil pans
Old 01-07-2014 | 01:01 PM
bigboat28's Avatar
Default 7.3 oil pans
What are you guys doing with the rusting leaking oil pans to fix it short of pulling motor to fix? Mine is not leaking yet but is badly rusting and flaking off and I have painted it earlier.
bigboat28 is offline
Old 01-07-2014 | 01:12 PM
Almost hate to admit it, but JB welded a temporary patch on mine .... 2 and a half years ago still good!
RT930turbo is offline
Old 01-07-2014 | 02:03 PM
2 choices pull the motor or cut the crossmember if you're good. And only if you're a talented welder/fabricator. Problem with pulling the motor is you end up doing manifolds, oil cooler, up pipes etc
Unlimited jd is offline
Old 01-07-2014 | 02:13 PM
Damian Diesel pan saver and never worry about it again.
VCMike is offline
Old 01-07-2014 | 02:26 PM
their is another way...i had to show up the guys at the dealer..remove fan and shroud,,remove the core support bolts and the first front cab bolts,,loosen the rear cab bolts,,loosen the trans mount bolts..raise the truck on the lift and set it on the locks..after you remove all the oil pan bolts and starter and motor mount bolts and when you jack the motor up and the trans hits the hump it will lift the cab with the engine enough to clear the trans and the pan falls out..make sure you have a strong engine jack...or you can jack the cab up first and put 4x4 between the cab mounts..watch the brake ang trans lines and ac hose's tho..i loke to do it all at once to keep from breaking lines ..
FIXX is offline
Old 01-07-2014 | 02:30 PM
Metal gas tank repair kit works great be quick it sets up real fast .
575cat is offline
Old 01-07-2014 | 03:26 PM
There is a local guy in Buffalo that will do 7.3 oil pans for $750. He lifts the motor. When mine goes I will cut and weld my crossmember.
79formula is offline
Old 01-07-2014 | 03:46 PM
northernoffshore's Avatar
http://www.youtube.com/watch?v=slnFCb46IO8
northernoffshore is offline
Old 01-07-2014 | 04:59 PM
Iit also has been done by pulling the turbo for more lift clearance .
575cat is offline
Old 01-07-2014 | 08:26 PM
seafordguy's Avatar
Look up the por-15 trick. I did it on mine and it lasted
seafordguy is offline
