Are Garmin Chart Plotters Smartcraft compatable? >
Old 01-08-2014 | 12:25 PM
Default Are Garmin Chart Plotters Smartcraft compatable?
Specifically looking at the 740.
Dave
08 fastech 292 is offline
Old 01-08-2014 | 12:28 PM
Dave
I have the 740s. I read that it is, although my engines are carbs so I have no personal experience.
joew. is offline
Old 01-08-2014 | 03:07 PM
if the smartcraft is NMEA compatible then probably yes
pstorti is offline
Old 01-08-2014 | 06:58 PM
Zero Patience's Avatar
Yes, thru nema 2000. But you will need a gateway from mercury, ($350.00) two cables and a port expander .
Zero Patience is offline
Old 01-09-2014 | 06:26 PM
Also will need a backbone for the nmea2000. You cannot plug the gateway into the back of the 740 directly. Both the 740 and gateway go to the backbone along with two terminators and pwr 12vdc. If you Garmin with external antenna and backbone you only need a tee
Double Rigged is offline
Old 01-10-2014 | 08:56 AM
C_Spray's Avatar
Diamond Member #001
Smartcraft is a proprietary Mercury communications protocol and, as such, will not communicate with ANY NMEA2000 chartplotter without a gateway. (Thanks, Mercury...)
On the positive side, I have a 740 and really like it. Since I am Ilmor-powered, there are no communication issues.
Attached Thumbnails Are Garmin Chart Plotters Smartcraft compatable?-dashat89.png
C_Spray is offline
