Flywheels the same or not
Old 01-09-2014 | 08:22 PM
Default Flywheels the same or not
I have a pair of fly wheels from 1990 Mercruiser 330 hp (454) inboards and replacement 496HO's. I/O's
Are these the same and were the 454's internal balance or external.
I was going to use the ones from my old motors if they are the same..
fastestonehere is offline
Old 01-09-2014 | 08:38 PM
454's are external.
Don't know about the 496 but I do know that between the Mark IV and the Gen V 454's there is a difference. It's small but enough that I wouldn't swap the 2.
f_inscreenname is offline
Old 01-10-2014 | 09:03 AM
they are MKIV so these are external bal. the new motors are 8.1 496.
also are the flywheels the same between inboard/outboard and inboard motors.
Old 01-10-2014 | 06:23 PM
As for a I/O and a inboard it all depends where the starter is installed. An inboard the ring gear is on the outside and I/O it's on the inside (because the starter is mounted to the block). Some you can just pull off the ring gear and put it on the other side but not flywheels can do this.
Old 01-10-2014 | 06:42 PM
/f_inscreenname thanks I just confirmed them and you were correct. Since the flywheel from my MKIV blocks appear to have a counter balance built in them with a few drill holes I assume they are External Balance correct?
So can the flywheel be neutral balanced.
Old 01-10-2014 | 08:40 PM
counter weight on the flywheel is external
It can be neutral balanced but you would be better off just buying a natural flywheel. Just bought one for a 427 stroker I'm building. 78.00 bucks
http://www.summitracing.com/search?S...ord=atp%20z296
Old 01-10-2014 | 09:07 PM
IF you are installing 496HO engines, you need to use the flywheel that came with them. If you will be using a TOP mount starter like a transmission boat, or inboard, then you need this flywheel.
http://www.michiganmotorz.com/inboar...nes-p-626.html
If it is for an I/O, you need this one.
http://www.michiganmotorz.com/sternd...nes-p-627.html
If its an I/O with bottom mount starter, you may be able to get a flywheel from a GM 8.1L truck engine. Like this
http://www.carpartkings.com/rhinopac...el-167576.html
MILD THUNDER is offline
Old 01-10-2014 | 09:28 PM
[QUOTE=MILD THUNDER;4055263]IF you are installing 496HO engines, you need to use the flywheel that came with them. If you will be using a TOP mount starter like a transmission boat, or inboard, then you need this flywheel.
This is the application that I am doing.. Can I just change ring gear on an I/O to the other side so it would work with top mount starter?
Old 01-11-2014 | 07:43 AM
yes, as long as the flywheel is machined on both sides, mine were not from GM gen VI marine engines, I had a machine shop cut the other side and I put the ring gear on and was fine...best to use flywheel that came with the engines...
ezstriper is offline
Old 01-11-2014 | 08:07 PM
why is it best to use the flywheel that came with the engine?
mike tkach is offline
