Windshield AT 37 >
Windshield AT 37
Windshield AT 37
Old 01-12-2014 | 05:32 PM
Default Windshield AT 37
Hi,
i have a question about the windshield on the newer 37's .
I have only 3 Flaps and they don't realy work well. The newer have a complete windshield.
Do they work good, how high are they over the hull ?
Greatings from Germany
Hans
Scarab28Germany is offline
Old 01-12-2014 | 06:45 PM
Hans,
I have a 33' that uses the same type of set-up. When Pat rigged our boat I asked that he install the windshield higher than normal. I would say mine is about 3 1/2 to 4" above the deck. I believe the standard mounting height is about 1" lower. I think ours works pretty good, for what it is. You're not going to get the same protection as a full winshield offers, like a Formula, but I find it to be a good compromise. It also depends how tall you are, as to where the wind hits you.
Steve
509 SC is offline
Old 01-14-2014 | 09:32 AM
Works great. In a normal driving configuration the wind goes over the top of your head and you can hold a conversation.
laszlo01 is offline
Old 01-14-2014 | 12:30 PM
Mine is 3.25 inches above the fairing and works very well. Like Laz said, it deflects the wind upward right over your head.
Mine was made/installed by the prior owner and not a factory part.
Griff is offline
Old 01-14-2014 | 12:53 PM
Hello Hans in Germany
Bob Morgan put them on this AT don’t know how good they worked 100 MPH boat.
http://midwestboatparty.com/forum/sh...Active-Thunder
LOTOWONTOPGUN is offline
Old 01-14-2014 | 04:17 PM
Hi you all,
thank's for answering.
Good to hear that it works.
I have two reasons because i look for a windshield. It's often sunny weather in Springtime here in Germany but temperature only at about 20 degre Celsius i belive that's mid 60's F. Nice when you sit in the sun but cold at 50mls, you need a jacked and a cap.
Second reason and more importend to me then to my wife, is the noise in the ears. I hear nothing then wind all the time. I just builded the motors up with some Whipple Chargers and like to hear how the run. I have Mercury Racing quiet CE Exhaust Boxes. I only hear the Chargers while accelerate and nothing else but wind. Even not the beeper when troublecodes are detected. With some Control lights i hope i can "see" the beeper.
When i drive a little faster i have always the head down to hear the motors corect running, that's grazy.
It's truly not a 100 mls boat with 2x 600 HP but i had 80 for a short test run . After this i had totaly red eyes even with a very good lens.
I belive i will find somebody here to get a shield cutted and make the angle by my self. I' not very tall so 3 1/2 inch will work for me when it works for you.
Greatings from cold wet Germany
Hans
Old 01-15-2014 | 10:06 AM
ROCKETMAN's Avatar
Hans
The windscreen is not that difficult to make yourself. The one Griff speaks of I made. Just remove the "crash pad" and take some cardboard to make a pattern. The Lexan/Polycarbonate was either 1/4" or 5/16" thick. I used a circular and a jig saw to cut it then sanded the edges, I then took a heat cut warming up the areas requiring bending/forming, after this I predrilled the holes larger than they needed to be so they wouldn't "snag" putting it on. I would suggest getting enough material in case you break one in the process of making/installing it. It was my first attempt in trying this and it turned out fine, however I did break one in the process.
I know some of the newer ones are much thicker but I don't think it's necessary, my 37' and several others are of the thinner type and have held up fine.
Steve
ROCKETMAN is offline
Old 01-17-2014 | 01:37 PM
Hi Steve,
I saw some YouTube Videos and they all cut with a disk saw to get a clean cut and use a welding torch to clear the edges. I found a firm who make the cut's and clear the cut surfaces. I want that it look professional and i belive i can not do it by my self like i want it. I can make the holes and the angles. The cut's and 2 rounded edges are not so expensive and no risk to brake it . I only would use a drill with a cut for plastic that i don't brake by drilling holes.
I belive the thinner material is easier to get between hull and "Crash pad" because there is not much space between Crash pad and side cover.
Greatings
Hans
