Hydraulic Roller Cams, etc.
Gen 6 step nose cams. All hydraulic roller:
1) Crane (NEW) 226/232 .587/.598 114 LSA (exhaust lobe cut on small block master for a little less lift and 2 degrees less duration) Designed for a nice idling EFI. Installed, but never ran. $150.00
2) Arizona Speed and Marine 224/230 .540/.540 114 LSA I believe this cam was ground by Schneider. This cam would be a good cam for an easy 454/502 mag mpi upgrade, with minimal headaches...had a nice, smooth idle and definitley more on top.Only needs moderate valve springs and stock roller lifters. I ran this cam for awhile and changed to an Ultradyne. Not even a season on this ASM cam. $100.00
3) Ultradyne (now Bullet) 226/234 .601/.601 114 LSA. I found out after I removed this cam, that it needs to be installed at 5 or 6 degrees advanced for a nice idle because of the assymetrical lobes. This cam had tons of power. It has a surface rust spot on the step nose journal appx. 1/8" in diameter and smaller spot on the flank of one of the lobes...I believe these will polish out.Because of this, I will sell for just
$40.00....pay for it after inspecting. Just pay 12.00 freight.
Again, all cams are step-nose, Gen 6.
Comp 929-16 valve springs; NEW but installed on cam #1 $75.00
Titanium Retainers;NEW but were installed on cam #1 $75.00
Would work a trade for 500/525 efi lower intake or Corsa asr tips.
Items located in Kansas City. If you are a familiar name in good standing on this forum, I'll send you the items to inspect first. Figure $12.00 shipping on cams. Thanks, Dave 816-516-6716
I'm pretty sure they would be 10*. I'll include the locks with them, however, the heads were set up with a 3/8" Inconel exhaust and 11/32" intake. You can look up the springs specs on Comp's site...they were and still are a recommended spring for the Crane hydraulic roller cams, although now on the lower end of the price scale.
