how are cables measured?
Old 01-16-2014 | 10:26 AM
Default how are cables measured?
i need to order k plane indicator cables for a boat that never had them. when i order cables is it overall length, threaded end to threaded end or is it the length of the jacketed part of the cable? is there anything i need to do to prevent water from entering the cable? it seems to me its a place for water entry
regalman4925 is offline
Old 01-16-2014 | 10:58 AM
I believe they are measured tip to tip . can you get the measurement off the old cables? (which should be about 1' from the end)
mickeymcclgn is offline
Old 01-16-2014 | 11:15 AM
97FASTech's Avatar
Veteran: Army
Here is a quick guide, thread to thread ie. tip to tip:
http://www.jamestowndistributors.com...t.do?docId=783
If you google " How to measure teleflex cable", you get tons of info.
97FASTech is offline
Old 01-16-2014 | 11:39 AM
Mickey, the boat does not have original cable, as mentioned the boat didn’t have K planes before. 97fastech, that’s what I think I need. I will look at it in depth her in a little bit
Old 01-21-2014 | 04:54 PM
If you call formula. Give them year and model . They will tell the correct length
I believe Scott is the guy you will tAlk with . I do every time
smokin' gun is offline
Old 01-21-2014 | 08:38 PM
Lightbulb
Id use inches.
ICDEDPPL is offline
Old 01-21-2014 | 09:12 PM
Baja,,he was responding to 97 fastech.....
FIXX is offline
