Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
Need professional input on these two boats , and the sellers . >
Old 01-16-2014 | 04:48 PM
Default Need professional input on these two boats , and the sellers .
I'm new here and yes I did take the time to read a few threads . I'm looking to purchase one of the following .
2009 Fountain 42 Lightning twin 1075 SCI - 0 hrs on motors
Seller is Pier 57
2008 Outerlimits 46 Limited twin 1075 SCI-84 hrs on motors
Seller is Performance boat center
The Outerlimits is more expensive , but I imagine thats because it's a bigger boat .
The boat will be running the waters of OC Md. and the Chesapeake bay .
What I am looking for is some input as to which is better and why ?
Approximate speeds , realistic ! Cruise speeds ? Full boost ?
Characteristics in rough water handling and in flat water .
We will say rough water is 3-4 feet .
Thanks for your time , much appreciated .
Bill
linumup is offline
Old 01-16-2014 | 05:50 PM
TYPHOON's Avatar
I hope this is not your first boat.
TYPHOON is offline
Old 01-16-2014 | 06:22 PM
No sir , my first boat was a 353 Formula and my second boat was a 48 Ocean Yacht .
linumup is offline
Old 01-16-2014 | 06:47 PM
Ryan Beckley's Avatar
Racer
Racer
Formula 42 lighting??? Buy the Outerlimits......
Ryan Beckley is offline
Old 01-16-2014 | 09:05 PM
Xtremeracing's Avatar
+ 1
Xtremeracing is offline
Old 01-16-2014 | 10:25 PM
Let's first assume you made a typo when you said Formula 42 Lightning. Either boat will handle the conditions you mentioned well. The OL will be a bit more comfy because of the size, but the 42 Fountain is one of the best riding boats made, so can't go wrong there either. The 1075's and #6 drives are both very costly to maintain.
The Fountain is priced where it is because of the engines and the custom graphics; that boat will run in the 130 mph range, I believe. Unless that's what you're after, you could get a 42 with 700's, that will run 100+ all day long and save yourself a LOT of dough both on the initial cost of the boat and the maintenance.
The Outer Limits boat is a bigger, heavier boat; apples and oranges I think. I can't comment on speeds; I have no seat time in an OL. But from what I've seen of it, it's stunning. I've been to their factory; they are a first class operation and make awesome boats.
Between these two, assuming the price difference is not a consideration and assuming both boats are comparable as far as condition, I'd go for the Outer Limits..
I'd be comfortable buying from either Pier57 or PBC..
HyFive578 is offline
Old 01-17-2014 | 09:10 AM
Yes it was a typo , locked in smartphone isnt so smart . So what is the issues with the 1075 SCI ? Why and what is costly . Performance boat center also has a 2008 42 lightning with twin 700s . Just some insight i am a gearhead and have several street racecars and drag cars . I do all my own tuning and datalogging . Wrenching and fabrication . I am by no means stating i know everything . But i am sure i can figure things out and have access to others if i cant . I want to have fun and enjoy the boat , i like the speed factor if i need it , but its not a necessity ! Id rather be on the water then waiting and spending money on parts .
What i have read is that they need to be freshened up every 300 hours , is that true or false ? Is the longevity better on the 700s ? Like i said i am doing some research now before i pull the trigger on anything ! If this was a car we wouldnt be having this conversation . But what i have learned from cars and boards/forums . There is indeed some good quality info out there . As well as bad !
linumup is offline
Old 01-20-2014 | 06:44 AM
purnell's Avatar
Outerlimits!
purnell is offline
Old 01-20-2014 | 08:46 AM
Gladhe8er's Avatar
1075's wont last close to 300 hours without a refresh. Figure pulleys every 40 hours and a full rebuilds every 125-150 hours.
Gladhe8er is offline
