air cleaner eld 1409
Old 01-18-2014 | 02:42 PM
Default air cleaner eld 1409
would you help me pick right aftermarket air cleaner for my cab eld1409 with marine type ,it bolt on 350 vortec,,,,,,,thanks
tk350 is offline
Old 01-20-2014 | 12:56 PM
Ayuh,.... The Edlebrock carbs use the same 5, 1/8" flame arresters as all the other 4bbl. carbs I've seen,...
Bondo is offline
Old 01-20-2014 | 06:11 PM
Guess my question is, why do you want an after market air filter when the standard flame arrestor will pass just as much if not more air with less restriction then and air filter
AllDodge is offline
Old 01-20-2014 | 06:23 PM
I had a holley high volume flame arrestor and it caused such a disturbance when I was on the dyno that it cost 20hp and had a nastly mid rpm lean spot. Whet to a K&N and everything was back to normal. Flame arrestors do matter.
ACrooks69 is offline
Old 01-30-2014 | 09:25 AM
thank for your post. I stay with stock standard flame arrestor .
tk350 is offline
