pn for 1997 502 mag MPI's fuel pressure regulator
I am going to order new regulators for my 1997 502's with VST's. Anybody have a part number handy. The "resident mechanic" at our marina let me use his pressure gauge at the end of the season as he stated with around 500hrs, he would bet they were reading low. Well he was right as Port was 34psi and SB was 38PSI.
Would everyone agree that the regulators are bad, or is there something else to look at in the VST system to alleviate the low PSI?
If you experiencing vapor lock the do to things; Stop using ethanol fuel and make sure you let the engine cool down on hot days before you turn it off.
I have the same setup as you with the VST in my cruiser and I would not be worried
I have found this site VERY helpful with both the part numbers and matching engine serial numbers to what they actually are.
http://www.perfprotech.com/mercruise.../04/mercruiser
