600sc drive ratio vs boost >
Old 01-22-2014 | 09:45 PM
Default 600sc drive ratio vs boost
Basically building a pair of intercooled 600sc clones looking for actual hard numbers on what everyones running for pullies and what the psi is with them.
Rbesola is offline
Old 01-23-2014 | 05:11 PM
Stock 600sc pulley ratio was .93:1 or basically 7% underdrive. I believe on the 600sc, it made about 5-6psi.
MILD THUNDER is offline
Old 01-23-2014 | 07:24 PM
I guess ill watch my guages close and make bigger pullies if it comes down to it.
Rbesola is offline
Old 01-23-2014 | 07:31 PM
You got the 16 Rib pulleys right ? Teague and blower shop have them in different sizes.
Can you get the exact measurments of the pulleys you got now top and bottom
Old 01-25-2014 | 06:25 PM
Ya. 6.3125 drive and 5.375 top which comes out to 17.442% overdrive
Rbesola is offline
Old 01-25-2014 | 06:31 PM
i have a pair od 600 sc..i put prochargers on them,,i still have the stock 10 rib lower
pullys ill give you a deal on,,but it looks like you may have the aftermarket 16 rib
FIXX is offline
Old 01-26-2014 | 06:44 AM
Yes they're 16 ribs
Rbesola is offline
