BBlades I need your help. >
Old 01-24-2014 | 04:33 PM
Default BBlades I need your help.
I was told by some people that on my boat a 98 28zx with 350 mag mpi's that i should be running a 23p mirage plus rh and a lh mirage 23p not plus. Is there any truth to that. Thanks in advance.
BIGMC69 is offline
Old 01-25-2014 | 02:09 AM
That makes no sense. You should run the same props on both sides and the rpms should be the same as long as both engines are equally healthy.
Griff is offline
Old 01-25-2014 | 04:46 AM
Must have been one of the Swamp People..
Rattlesnake Jake is offline
Old 01-25-2014 | 11:08 AM
Yep I agree makes no sense at all. Just checking
BIGMC69 is offline
Old 01-27-2014 | 10:56 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Agreed, props should match no matter what brand or model or size.
Brett
[email protected]
bbladesprops is offline
