Professional Mariner 3 Bank on board Battery Charger/Conditioner Automatic
I bought this a few years ago, installed it in the Scarab I was trying to build as I thought I was putting an extensive stereo system in the boat, then never ever got to use this boat. So this has been installed but is what I would call still new.
Comes with original box and instructions. Provides up to 360 amp hours per day. Can be used with lead/acid or gel/agm batteries. Can be used with 120 or 240 VAC.
Charges/maintains up to three 12 volt batteries. Built in automatic temperature activated cooling fan. Fully automatic operation. overload, short circuit, ignition protected.
MUST BE MOUNTED IN A DRY LOCATION
Hooked it up today to show in pics that it is working.
I paid over $200 for it a few years ago and again, has seen no use.
Sell for $150 to your door!
Overall length including wiring connections is about 8"
Length of the charger body is 6 3/4"
Overall width including mounting area is 8 1/2"
Body width is 7 1/2"
Height is about 4 1/8"
Also should mention that the whole body is made of aluminum. Not cheap plastic.
